SJCAM SJ4000 Plus WIFI Novatek 96660 1.5 Pulgadas LCD Pantalla 2K 30FPS Impermeable
coolicool
CooliCool Oficial
13 Mar 2014
Las cámaras deportivas de la Marca SJCAM están entre los artículos más vendidos hasta ahora.
La buena noticia es: este mes, se lanza el nuevo SJCAM SJ4000 Plus!!!!! ¿Te toca el corazón? Vamos a ver los detalles!
SJCAM SJ4000 Plus WIFI Novatek 96660 1.5 Pulgadas LCD Pantalla 2K 30FPS Impermeable Cámara Deportiva con 170° Ángulo Amplio Lente
Particularidades
♦ 12 Megapixel CMOS Sensor with HD wide-angle lens
Chipset: Novatek 96660
♦ Wi-Fi Function, the user can operation or review via Android or for iOS Device
♦ Mini appearance, diversified colors available
♦ A water-resistant casing that allows you to film fascinating water sports
♦ Multiple photo shooting modes: Single shot, Snapper
Multiple video recording formats: 2K(2560*1440)30FPS; 1080P(1920*1080)60FPS
♦ Water-resistant up to 30 meters under water
High definition screen that displays and replays fascinating videos recorded
♦ Support HDMI HD output function
♦ Detachable battery that is easy to replace and prolongs your cameras service life
♦ Support storage cards up to 32GB maximum(Micro SD Card Class6 Above,Not included in package)
¿Lo quieres comprar? Haz clic aquí para obtener información>>http://es.coolicool.com/sjcam-sj400...-30fps-impermeable-camara-deportiva-g-1239662
https://www.youtube.com/watch?v=fRDgJ-wxmek
