DRIVER POWER STATE FAILURE , pantallazo azul
antonio18_
31 May 2014
Desde hace unos días, que de repente me deja de ir el teclado por blueetooth y algunos usbs, y de repente me sale pantallazo azul con: DRIVER POWER STATE FAILURE.
Enciendo el bluescreenview y esto es lo que me sale:
Llevo días miradno y no sé que pasa. Todos mis drivers están actualizados, solo tengo uno deshabilitado y que es el blueetoth de la placa base, dado que no me coge el teclado y debo usar un blootooth externo.
Y el crashdump me indica lo siguiente:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Wed 04/02/2015 2:15:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020415-9750-01.dmp
This was probably caused by the following module: hal.dll (hal+0x539A)
Bugcheck code: 0x9F (0x3, 0xFFFFE000A6A891D0, 0xFFFFD00112A6A960, 0xFFFFE000B156B940)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Tue 03/02/2015 1:21:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020315-9546-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x150AA0)
Bugcheck code: 0x9F (0x3, 0xFFFFE000A5667E20, 0xFFFFD000ADB63960, 0xFFFFE000A56AB010)
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Haz un punto de restauración antes y prueba esto después:
  • Arrancar la máquina con el cd de instalación del sistema.
  • Iniciar la consola de reparación siguiendo las instrucciones en pantalla para tal fin.
  • Escribir: attrib -R-H-S C:\boot .ini
  • Escribir: del C:\boot .ini
  • Escribir: bootcfg /rebuild
  • Escribir: fixboot
  • Tras reiniciar el sistema todo debería haber vuelto a la normalidad
Prueba lo que te dice nos, pero de todos modos estos "crashes" se deben a problemas/incompatibilidad de drivers, asi que no hay garantia de que no te vuelva a ocurrir si sigues usando los mismos perifericos problematicos... Intenta actualizar los drivers de todos los dispositivos, y si sigue igual la unica solucion sería desinstalar los controladores con errores. Metete en el Administrador de dispositivos y mira a ver cuales son los disposit¡vos que tienen problemas.
Salu2
