NB Frequency y HT Link Speed
@Mussoniu
A ver, párate.
La segunda imagen que me pasaste dices que lo hiciste por offset -0.100V ???? como puse en mi 1ª y 2ª captura??
No lo había visto
@Mussoniu
A ver, párate.
No lo había visto
Si, así es.
Enviado desde mi Moto G (4) mediante Tapatalk
juanvi67
He tenido que salir, estoy de guardia esta noche y toca currar.
No creo tardar mucho en volver, en cuanto llegue me pongo con ello.
cc
@Mussoniu. Vale. Pues seguiremos por offset como has empezado.
[TABLE="class: MsoNormalTable, width: 1119"]
[TR]
[TD="width: 107"]
Mhz
[/TD]
[TD="width: 64"]
Vcore
[/TD]
[TD="width: 80"]
load-cpu
[/TD]
[TD="width: 70"]
idle-load
[/TD]
[TD="width: 73"]
Offset
[/TD]
[TD="width: 83"]
load
[/TD]
[TD="width: 55"]
idle
[/TD]
[TD="width: 40"]
CPU
[/TD]
[TD="width: 35"]
mb
[/TD]
[TD="width: 30"]
T0
[/TD]
[TD="width: 48"]
T1
[/TD]
[TD="width: 30"]
T2
[/TD]
[TD="width: 65"]
T3
[/TD]
[TD="width: 66"]
VIN0
[/TD]
[TD="width: 68"]
CPU/NB
[/TD]
[TD="width: 65"]
NB v
[/TD]
[TD="width: 66"]
HT
[/TD]
[TD="width: 50"]
SB
[/TD]
[TD="width: 75"][/TD]
[TD="width: 75"]
Fecha
[/TD]
[TD="width: 51"]
Hora
[/TD]
[TD="width: 83"]
Temp
[/TD]
[TD="width: 68"]
CB 8
[/TD]
[TD="width: 50"]
CB 1
[/TD]
[TD="width: 50"][/TD]
[TD="width: 50"]
rpm
[/TD]
[TD="width: 62"]
Corsair
[/TD]
[TD="width: 210, colspan: 6"]
RAM = 1,65V
[/TD]
[/TR]
[TR]
[TD="width: 107"]
De serie
[/TD]
[TD="width: 64"]
1,464
[/TD]
[TD="width: 80"][/TD]
[TD="width: 70"][/TD]
[TD="width: 73"][/TD]
[TD="width: 83"]
1,464
[/TD]
[TD="width: 55"]
[/TD]
[TD="width: 40"]
51
[/TD]
[TD="width: 35"]
27
[/TD]
[TD="width: 30"]
45
[/TD]
[TD="width: 48"]
38
[/TD]
[TD="width: 30"]
55
[/TD]
[TD="width: 65"]
27
[/TD]
[TD="width: 66"]
1,475
[/TD]
[TD="width: 68"]
1,177
[/TD]
[TD="width: 65"]
1,118
[/TD]
[TD="width: 66"]
1,217
[/TD]
[TD="width: 50"]
1,105
[/TD]
[TD="width: 75"]
02-06-18
[/TD]
[TD="width: 51"]
22:00
[/TD]
[TD="width: 83"]
22º
[/TD]
[TD="width: 68"]
710
[/TD]
[TD="width: 50"]
110
[/TD]
[TD="width: 50"]
1680
[/TD]
[TD="width: 62"]
31
[/TD]
[TD="width: 48"]
805
[/TD]
[TD="width: 32"]
11
[/TD]
[TD="width: 32"]
11
[/TD]
[TD="width: 32"]
11
[/TD]
[TD="width: 32"]
[/TD]
[TD="width: 32"]
39
[/TD]
[/TR]
[TR]
[TD="width: 107"]
4471MHz
[/TD]
[TD="width: 64"]
1,380
[/TD]
[TD="width: 83"]
1,396
[/TD]
[TD="width: 55"]
1,376
[/TD]
[TD="width: 40"]
48
[/TD]
[TD="width: 35"]
27
[/TD]
[TD="width: 30"]
43
[/TD]
[TD="width: 48"]
36
[/TD]
[TD="width: 30"]
53
[/TD]
[TD="width: 65"]
27
[/TD]
[TD="width: 66"]
1,396
[/TD]
[TD="width: 68"]
1,164
[/TD]
[TD="width: 65"]
1,118
[/TD]
[TD="width: 66"]
1,217
[/TD]
[TD="width: 50"]
1,105
[/TD]
[TD="width: 75"]
02-06-18
[/TD]
[TD="width: 51"]
22:00
[/TD]
[TD="width: 83"]
22º
[/TD]
[TD="width: 68"]
710
[/TD]
[TD="width: 50"]
110
[/TD]
[TD="width: 50"]
1020
[/TD]
[TD="width: 62"]
29,8
[/TD]
[TD="width: 48"]
948
[/TD]
[TD="width: 32"]
10
[/TD]
[TD="width: 32"]
11
[/TD]
[TD="width: 32"]
10
[/TD]
[TD="width: 32"]
30
[/TD]
[TD="width: 32"]
42
[/TD]
[/TR]
[/TABLE]
Para que te vayas entreteniendo
De momento hemos bajado:
Voltaje CPU de 1,464V a 1,380V
CPU de 51 a 48º
mb = Motherboard
Estas temps no sé exactamente qué son:
T0 Serán los cores
T1 Placa
T2 Puede ser el NB
T3 Puede ser el pci
La Corsair de 31.4 a 31.3º RPM de 1680 a 1560
La ram sigue estando a 1.65V. De stock te la ponía a 1600 MHz.
La bajaremos a 1.50V si podemos. Ahora la pusiste a 1866 MHz como dije.
Voy a modificar el mensaje anterior que te puse para Manual. Así seguimos por Offset ya que tengo tus capturas.
juanvi67 acabo de volver justo ahora, que se alargó un poco la urgencia.
He visto el mensaje modificado, discúlpame por el lio con el voltaje Manual y el Offset.
Cuando le he hecho undervolt anteriormente ha sido jugando directamente con el Offset, de ahí a confundirme y pasar por alto hacerlo primero con el voltaje Manual.
Me parece bien bajarlo a 4.2Ghz y afinarlo a esa frecuencia. Para los dias de mucho calor seguro que me viene de perlas. Seria incluso buena idea guardarme varios perfiles e ir jugando con ellos dependiendo de la situación.
He puesto el voltaje de las memorias RAM en 1.5v, se me habia pasado ajustarlo.
Respecto a las temperaturas que no reconocias creo que son así:
T0 Coincide con otra temperatura de la placa
T1 Puente Sur
T2 Puente Norte
T3 Placa Base
Te adjunto la siguiente captura:
Voy a ponerme a hacerle las pruebas que me has comentado jugando con el voltaje, cuando llegue al fallo te comento.
cc
Un mensaje era tuyo al citarme.
Primero vamos a continuar a 4.4 GHz y seguir bajando voltaje como he puesto y modificado. Por Offset vale. No sé si has entendido mi explicación, aunque parezca incongruente subir un número para bajar el voltaje de cpu. Me quedo más tranquilo si dices que ya tienes experiencia en ello.
En realidad se hace primero por manual desactivando los ahorros de energía desde bios, apm y demás, pero nada olvídate y continua como antes.
Qué versión de Aida tienes? Pulsa en Ayuda y te saldrá
Menudo lio estoy haciendo :meparto:.
Te habia entendido de hacerlo sobre 4.2Ghz, las noches que tengo de guardia me vuelven loco. Igualmente me sirve como toma de contacto y voy rompiendo mano, disculpame si te estoy mareando mucho.
Te comento lo que ha sucedido hasta ahora:
-Con 4.2Ghz
Con el Offset he l legado hasta -0.20000 que en Windo ws me daba un valor de 1.284v.
Al reiniciar para seguir aumentando el Offset, guardo configuración en Bios y salgo, el pc no tiraba daba error 5d y al darle al boton de reiniciar F.F. Por lo que me tocaba tirar de Clear Bios y cargar la configuración de nuevo, pero con un punto menos (0.00625v). Así hasta un Offset de -0.175000 equivalente en Windows a 1.308v, con el cual al guardar y salir de Bios se quedo medio colgado, pero pulsando el boton de reinicio arrancó.
La version de Aida64 5.95.4500.
cc
No pasa nada, pero tardaremos más. era mejor a 4.4 y hubiera petado antes.
Bueno a 4.2 el último con el que pasate el CB era con offset -1.200 no?
Entonces súbele 0.00625 al -1.200, quedando en bios -1.20625 o dos puntos a -1.2125 y cuentas. El punto sólo es para afinar y tardar menos, pero ya está cerca. Sigue
He tenido que salir de nuevo. Un noche movida...
Si no tardo en volver, me pondré con ello. Si no, mañana por la mañana te pondré por aquí cosillas.
Ya dices.
Hola @juanvi67.
Ahora que estoy mas fresco y puedo atender a esto bien, voy a comentarte como se encuentra todo:
1- Clear cmos
Tenia que recurrir a este botón una vez había guardado la nueva configuración de en Bios y se reiniciaba el pc, durante los primeros segundos del post se quedaba colgado.
Lo curioso de esto es que, anoche conseguí llegar en offset a -0.20000, hice el CB R15 sin ningun problema y al entrar en Bios de nuevo para volver a aumentar el offset me dió el primer fallo, así teniendolo que bajar hasta -0.175000 pareciendo ya estable. Pero esta mañana cuando he encendido el pc me ha salido el mismo error 5d y he tenido que hacer clear cmos.
2- Overdrive o Prime95
Voy a instalar Overdrive para ir probando, cuando puedas me dices si para Prime95 he de configurar algún parámetro o algo en concreto y en Overdrive en la parte de "Prueba de estabilidad" imagino que habré que seleccionar todos los puntos.
3- 4.2Ghz
Voy a dejar de lado esa frecuencia y a empezar de nuevo con 4.4Ghz y realizarlo con el modo Manual. No entiendo mucho por que anoche me dejo llegar en offset a -0.20000 y esta mañana al arrancar el pc no aguantaba ni -0.175000.
4- Temperaturas y frecuencias
Siempre lo tengo a la vista con HWinfo desde otra pantalla que habitualmente la dedico solo a eso.
5- Ahorros de energia
En tu guía de Ryzen comentas desactivar estos ahorros de energia:
La equivalencia para mi placa seria la de la captura que subiste? Tal que así?:
5.0 Gz
@Mussoniu no te había citado. Hola, buenos días
Cuando accedes a bios qué primera pantalla te sale: los gráficos o el modo avanzado (F7)?
Dime cómo tienes el segundo valor "CPU Level Up" y "Extreme OV"
Sabes capturar pantallas dentro de bios?
Mete un pendrive. Cuando estés en Extremme Tweaker pulsas F12 y se añadirá una imagen al usb.
1. Pon offset a -0.150.
2. Con uno sobraba. Prime es algo más agresivo.HAzlo con el que te sientas tú más cómodo.
a) Para ejecutar prime 95 > Options > Torture Test > "Blend" estará señalado > OK
Cuando observes que las líneas suben un par de veces puedes pararlo y continuar bajando Vcore o subiendo Offset, es lo mismo. 0.0125 V vale?
Estar pendiente por si te sale error en algún core "Not Worked" o algo similar.
b) Para seleccionar todo en Overdrive hay un botón que lo hace, te colocas en la barrita y la tiras a la izda. Ahora a la drecha hasta 6 ó 9 min. suficientes para una primera toma de contacto.
Ya te dirá si falla que no ha pasado el test y se parará.
3. Ya que casi la tenemos, vamos a terminarla a 4.2 con las capturas o valores del voltaje cpu que marque el cpuz como puse anoche.
4. HWinfo lo puedes tener en el mismo monitor en segundo plano como cuando pasas la captura con el CB 15. Como veas.
5. No. En esa captura están habilitados todos los ahorros de energía. Ponlos en disabled, excepto HPC Mode en Enabled.
En estas frecuencias 4.2 - 4.4 no pasa nada, pero para oc's altos hay que tener cuidado 4.8 - 5.0 Gz
juanvi67 aquí te dejo la captura de Bios:
Así lo tengo ahora. Más la memoria ram a 1.5v y los ahorros desactivados menos el HPC.
Está bien, rematemos a 4.2Ghz ya que lo hemos empezado así con el Offset y demás.
Ahora mismo lo tengo todo como te comento aquí, de las capturas que pusiste anoche cambio algun valor más? o me ciño un poco a la guía de Ryzen? Quiero decir... para tenerlo claro, respecto a las capturas de anoche? sigo copiando la configuración tal cual pusiste?
cc
@Mussoniu No grabaste anoche la bios a x21 offset -0.150? porque como a -0.175 te dio fallo...
Ahora te está haciendo un oc automático el Ai Overclock Tuner. Hay que dejarlo Manual
Bueno, pues volvemos a empezar. Para frecuencias hasta 4.5 - 4.6 no vas a tener temps elevadas.
F5 y carga bios por defecto. Lo hacemo Manual que es + sencillo.
Para que la ram no cause inestabilidad subimos las latencias ya que con DOCP dices que no te funcionaban. A ver si va a ser esa la causa.
Valores de tus memorias según el enlace: (Si sabes los timmings que tenías con 1866MHz los pones)
• JEDEC: DDR3-1600 CL11-11-11 @1.5V
•XMP Profile 1 : DDR3-2400 CL11-13-14 @1.65V
•XMP Profile 2 : DDR3-2133 CL11-13-13 @1.6
**Todos los ahorros desactivados, toda esa página, incluso HPC Mode, todos.
[TABLE="class: grid, width: 500"]
[TR]
[TD]Ai Overclock Tuner[/TD]
[TD][/TD]
[TD]Manual[/TD]
[/TR]
[TR]
[TD]CPU Level Up[/TD]
[TD][/TD]
[TD]CANCEL[/TD]
[/TR]
[TR]
[TD]CPU Ratio[/TD]
[TD][/TD]
[TD]21.0[/TD]
[/TR]
[TR]
[TD]Turbo CORE[/TD]
[TD][/TD]
[TD]Disabled[/TD]
[/TR]
[TR]
[TD]CPU Bus Frequency[/TD]
[TD][/TD]
[TD]200[/TD]
[/TR]
[TR]
[TD]PCIE[/TD]
[TD][/TD]
[TD]Auto[/TD]
[/TR]
[TR]
[TD]Memory Frequency[/TD]
[TD][/TD]
[TD]DDR3-1600[/TD]
[/TR]
[TR]
[TD]CPU/NB Frequency[/TD]
[TD][/TD]
[TD]2200[/TD]
[/TR]
[TR]
[TD]HT Link Speed[/TD]
[TD][/TD]
[TD]2200[/TD]
[/TR]
[TR]
[TD]CPU Spread Spectrum[/TD]
[TD][/TD]
[TD]Disabled[/TD]
[/TR]
[TR]
[TD]PCIe " "[/TD]
[TD][/TD]
[TD]Disabled[/TD]
[/TR]
[TR]
[TD]EPU[/TD]
[TD][/TD]
[TD]Disabled[/TD]
[/TR]
[TR]
[TD]Extreme Tweaking[/TD]
[TD][/TD]
[TD]Disabled[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]DRAM Timing Control[/TD]
[TD][/TD]
[TD]11-11-11 resto Auto[/TD]
[/TR]
[TR]
[TD]DIGI+[/TD]
[TD][/TD]
[TD]De serie "F5" No tocar[/TD]
[/TR]
[TR]
[TD]**Desactivar Ahorros ahora[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Extreme OV[/TD]
[TD][/TD]
[TD]Disabled[/TD]
[/TR]
[TR]
[TD]CPU & NB V.[/TD]
[TD][/TD]
[TD]Manual[/TD]
[/TR]
[TR]
[TD] • CPU Manual V.[/TD]
[TD="align: center"]1,488[/TD]
[TD]1,350000[/TD]
[/TR]
[TR]
[TD] • CPU/NB Man V[/TD]
[TD="align: center"]1,137[/TD]
[TD]1,200000[/TD]
[/TR]
[TR]
[TD]CPU VDDA V.[/TD]
[TD="align: center"]2,500[/TD]
[TD]Auto[/TD]
[/TR]
[TR]
[TD]DRAM V.[/TD]
[TD="align: center"]1,500[/TD]
[TD]1.50000[/TD]
[/TR]
[/TABLE]
Todos los demás en Auto
ufff.
Si arranca, prime95... y a bajar voltaje
Si no arranca, subir voltaje.
Cuando lo tengas, saca captura e incluye las temps de Aida (para anotar las temps VRM de la placa)
Dime el CPU V del cpuz en idle y en load. Saca capturas de cpuz pestañas Cpu y Memory.
Hola juanvi67.
Hoy no he podido hacer casi nada, un par de pruebas nada más.
La Bios de anoche era tal cual la de tus capturas pero a x21. Algo no debia estar bien para mi CPU y por eso tiraba fallo.
Ahora tengo la configuración tal cual la de la tabla, he podido hacer una primera prueba con el CPU Manual V. en 1.350000v, ahora voy a bajarlo 0.025v y a hacer otra prueba.
Cuando dices:
"Cuando lo tengas, saca captura e incluye las temps de Aida (para anotar las temps VRM de la placa)
Dime el CPU V del cpuz en idle y en load. Saca capturas de cpuz pestañas Cpu y Memory."
Te refieres a cuando haya llegado al fallo, no?
Nuevamente, gracias por el tiempo que estas invirtiendo.
-----Añadido-----
He podido hacer varias pruebas. Ahora mismo en Bios he bajado hasta 1.25000v en el CPU Manual V.
Prime95 no me daba fallos pero no tengo tiempo de seguir con ello ahora, así que mañana por la mañana seguiré bajando a ver hasta dónde llega.
Un saludo!
es.
Cada vez que hago un stres test siempre anoto resultados en una base excell y hago mis capturas por si me equivoco al poner algún dato en la hoja que no me cuadre.
Por ejemplo en tu caso me haría algo así:
[TABLE="class: grid, width: 1160"]
[TR]
[TD="width: 1335, colspan: 19"]
OC MANUAL Ahorros Disabled NB = HT = 2200; Ram 1600 MHz @ 1,50V
[/TD]
[/TR]
[TR]
[TD="width: 144, align: center"][/TD]
[TD="width: 105, align: center"]CPU V[/TD]
[TD="width: 105, align: center"]idle[/TD]
[TD="width: 47, align: center"]load[/TD]
[TD="width: 95, align: center"]idle-load[/TD]
[TD="width: 105, align: center"]cpuV-idle[/TD]
[TD="width: 46, align: center"]CPU[/TD]
[TD="width: 35, align: center"]mb[/TD]
[TD="width: 53, align: center"]T0[/TD]
[TD="width: 32, align: center"]T1[/TD]
[TD="width: 35, align: center"]T2[/TD]
[TD="width: 56, align: center"]vrm1[/TD]
[TD="width: 56, align: center"]vrm2[/TD]
[TD="width: 63, align: center"]H115i[/TD]
[TD="width: 59, align: center"]Fan[/TD]
[TD="width: 63, align: center"]Pump[/TD]
[TD="width: 107, align: center"]Fecha[/TD]
[TD="width: 67, align: center"]Hora[/TD]
[TD="width: 62, align: center"]Tamb[/TD]
[TD="width: 70, align: center"]CB 8[/TD]
[TD="width: 73, align: center"]CB 1[/TD]
[/TR]
[TR]
[TD="width: 144"]
4471Mhz
[/TD]
[TD="width: 105"]
1,38000
[/TD]
[TD="width: 105, align: center"][/TD]
[TD="width: 47, align: center"][/TD]
[TD="width: 95, align: center"][/TD]
[TD="width: 46"]
48
[/TD]
[TD="width: 35"]
27
[/TD]
[TD="width: 53"]
43
[/TD]
[TD="width: 32"]
36
[/TD]
[TD="width: 35"]
53
[/TD]
[TD="width: 56, align: center"][/TD]
[TD="width: 63"]
30,4
[/TD]
[TD="width: 59"]
1560
[/TD]
[TD="width: 63"]
1879
[/TD]
[TD="width: 107, align: center"]02-06-18[/TD]
[TD="width: 67, align: center"]15:30[/TD]
[TD="width: 62, align: center"]25º[/TD]
[TD="width: 70"]
710
[/TD]
[TD="width: 73"]
110
[/TD]
[/TR]
[TR]
[TD="width: 144"][/TD]
[TD="width: 105"][/TD]
[TD="width: 47"][/TD]
[TD="width: 95"][/TD]
[TD="width: 46"][/TD]
[TD="width: 35"][/TD]
[TD="width: 53"][/TD]
[TD="width: 32"][/TD]
[TD="width: 56"][/TD]
[TD="width: 63"][/TD]
[TD="width: 59"][/TD]
[TD="width: 107"][/TD]
[TD="width: 67"][/TD]
[TD="width: 62"][/TD]
[/TR]
[TR]
[TD="width: 105"]
0,01250
[/TD]
[TD="width: 105"]
0,00625
[/TD]
[TD="width: 95"]
V droop
[/TD]
[TD="width: 105"]
V drop
[/TD]
[TD="width: 53"]
sock
[/TD]
[TD="width: 32"]
SB
[/TD]
[TD="width: 35"]
NB
[/TD]
[/TR]
[TR]
[TD="width: 144"]
4200Mhz
[/TD]
[TD="width: 105"]
CPU V
[/TD]
[TD="width: 105"]
idle
[/TD]
[TD="width: 47"]
load
[/TD]
[TD="width: 95"]
idle-load
[/TD]
[TD="width: 105"]
cpuV-idle
[/TD]
[TD="width: 46"]
CPU
[/TD]
[TD="width: 35"]
mb
[/TD]
[TD="width: 53"]
T0
[/TD]
[TD="width: 32"]
T1
[/TD]
[TD="width: 35"]
T2
[/TD]
[TD="width: 56"]
vrm1
[/TD]
[TD="width: 56"]
vrm2
[/TD]
[TD="width: 63"]
H115i
[/TD]
[TD="width: 59"]
Fan
[/TD]
[TD="width: 63"]
Pump
[/TD]
[TD="width: 107"]
Fecha
[/TD]
[TD="width: 67"]
Hora
[/TD]
[TD="width: 62"]
Tamb
[/TD]
[/TR]
[TR]
[TD="width: 144"]
10' Prime95
[/TD]
[TD="width: 105"]
1,35000
[/TD]
[TD="width: 95"]
[/TD]
[TD="width: 105"]
[/TD]
[TD="width: 107"]
[/TD]
[TD="width: 67"]
[/TD]
[TD="width: 62"]
[/TD]
[/TR]
[TR]
[TD="width: 144"]
10' Prime95
[/TD]
[TD="width: 105"]
1,33750
[/TD]
[/TR]
[TR]
[TD="width: 144"]
10' Prime95
[/TD]
[TD="width: 105"]
1,32500
[/TD]
[TD="width: 143, colspan: 2"]
Cinebench
[/TD]
[/TR]
[TR]
[TD="width: 144"]
10' Prime95
[/TD]
[TD="width: 105"]
1,31250
[/TD]
[TD="width: 70"]
CB 8
[/TD]
[TD="width: 73"]
CB 1
[/TD]
[/TR]
[TR]
[TD="width: 144"]
10' Prime95
[/TD]
[TD="width: 105"]
1,30000
[/TD]
[TD="width: 70, align: center"]?
[/TD]
[TD="width: 73, align: center"]?[/TD]
[/TR]
[TR]
[TD="width: 144"]
15' Prime95
[/TD]
[TD="width: 105"]
1,29375
[/TD]
[/TR]
[TR]
[TD="width: 144"]
Error Prime
[/TD]
[TD="width: 105"]
1,28125
[/TD]
[TD="width: 67"]
[/TD]
[/TR]
[/TABLE]
idle = Vcore sin carga o en reposo
load = Vcore en carga
Esos dos voltajes tienen que ser lo más próximos posibles. Eso lo ves con hwinfo o cpuz que es más simple y los vas anotando
El Vdrop (Disminución del Voltaje) es la diferencia del voltaje configurado en la BIOS con el voltaje que recibe realmente el procesador cuando está sin carga de trabajo (en Idle)
El Vdroop (Caída del Voltaje) es la diferencia entre el voltaje del procesador sin carga (idle) y el voltaje del procesador en carga (load).
Repasa el spoiler LLC de Ryzen que nos hará falta entenderlo para afinar el oc que estás terminando.
De ahí que necesites saber qué voltajes tienes en cada momento en carga, en reposo, qué temps, etc. Al final te aprenderás de memoria el Vcore para cada frecuencia: 4.2 - 4.4 - 4.6 - .....
Si no me lo dices yo voy un poco perdido. De ahí que me tengas que pasar capturas como hacías porque tú lo ves en pantalla, yo solo veo lo que me mandes.
La Fecha y la hora es muy importante. No es igual hacer oc a las 05.00 h. que a las 15.00 h porque la temp en tu habitación no será la misma a no ser que siempre uses aire acondicionado.
Quiero que vayas rellenando esta tabla con indicación del Vcore cuando crasheó, como puse en el ejemplo en rojo.
Joder se me ha cerrado la sesión con todo lo que te había explicado...
Bueno, imagina que falle el prime95 en cualquier core a 1,28750
Subes CPU V un punto 0,00625 quedando en 1,29350 Vuelves a ejecutar prime a 1,29350, esta vez durante 16 minutos. Posiblemente te dé error. Vuelves a subir otro punto quedando en 1,30000V que seguramente ya no fallará y ese será el vcore mínimo estable para 4200 MHz.
A partir del minuto 16 y sin detener prime haces una captura similar a la que te he realzado y ya lo detienes.
La captura y TODA la tabla rellena, las guardas en una carpeta llamada 4200 y me pasas ambas cosas.
Envía tmb una captura de cpuz: pestaña Memory y SPD para ver cómo han quedado las memorias ram.
En hwinfo, oculta:
SMART Samsung, SMART WD, Drive Samsung, Drive WD, GPU, PSU. Para OC a la cpu no es necesario tenerlos visible.
Sí que interesa revelar el Core # Vid 1.488. Sobre todo te hará falta al transformar el oc manual a offset, para que te relaje frecuencias en idle y no vaya siempre al máximo de frecuencia (a tope) ya que lo único que consigues es mayor consumo y mayores temps...
Ejemplo para 4200MHz en Manual, necesitas +/- 1.30V (Guarda el perfil en bios) aunque yo los guardo con offset ya relajado.
Para saber qué voltaje offset necesitas sería: 1,488 - 1,300 = un offset negativo de 0.188V
Realmente no es del todo certera la fórmula ya que varían otros factores por lo que habrá que afinarlo de nuevo en offset.
Como factores tendremos:
bajar latencias o subir frecuencias de Ram ya lo veremos.
habilitar Ahorros cool & quiet y demás
habilitar Plan de energía de windows Equilibrado
O bien, sigue con Manual y averguas el VCore mínimo para 4400MHz. Ya haremos el offset de 4200 y 4400 mientras vas cogiendo práctica en Manual.
Un saludo. Cualquier cosa ya sabes.
Hola juanvi67.
Tengo que aparcar el tema un par de semana minimo.
No tengo suficiente tiempo al final de dia ahora para dedicarle a esto, así que voy a esperar hasta que me den las vacaciones por lo menos para poder hacer el underclock, como ahora mismo tampoco tengo tiempo para jugar no me preocupan mucho las temperaturas.
A ver si en cosa de unas semanas puedo ponerme a ello, empezaré con pruebas y te lo documentaré por aquí para que me vayas comentando cosillas.
Gracias por la info que me has dado y demás!
Hola. Gracias por la info que me has dado y demás!
Hola. Bueno lo que querías que era bajar temps ya lo tienes, ya sabes como proceder. Luego ya sería buscar el LLC correcto para tener el menor vdroop posible.
Lo único que te vuelvo a repetir es que después lo dejes igual al mismo voltaje, pero mediante offset y activando ahorros excepto turbo.
Y en windows activar Equilibrado (Balanced), en vez de alto rendimiento.
Ah, e intentar subir la frecuencia de esas memorias con 1.60 y 1.65V.
Por aquí estaré no te preocupes. OK.
