lorenforce
- 6 Mar 2021
hola alguien me puede ayudar a configurar correctamente el color para mi monitor para saber que ajustes son los mejores en nvidia panel, en windows y en perfil de color(solo me sale este IEC 61966-2.1 Default RGB colour space - sRGB) os enseño un archivo de texto con todas las especificaciones de mi monitor,gracias decir yambien que busco una configuracion correcta para juegos espero vuestra ayuda
Monitor Asset Manager Report, generated 16/09/2023
Copyright (c) 1995-2019, EnTech Taiwan.
Monitor #1 [Real-time 0x0100]
Model name............... XGM27RGBF
Manufacturer............. KOT
Plug and Play ID......... KOT2700
Serial number............
Manufacture date......... 2020, ISO week 44
Filter driver............ None
EDID revision............ 1.4
Input signal type........ Digital (DisplayPort)
Color bit depth.......... 8 bits per primary color
Color encoding formats... RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
Screen size.............. 600 x 330 mm (27,0 in)
Power management......... Active off/sleep
Extension blocs.......... 1 (CEA/CTA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Mstar 0x1600
Firmware revision........ 0.1
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ 183,60kHz, 165,11Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,663 - Ry 0,328
Green chromaticity....... Gx 0,271 - Gy 0,596
Blue chromaticity........ Bx 0,134 - By 0,124
White point (default).... Wx 0,313 - Wy 0,329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 180-180kHz
Vertical scan range...... 48-165Hz
Video bandwidth.......... 450MHz
CVT standard............. Not supported
GTF standard............. Supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 165Hz (16:9)
Modeline............... "1920x1080" 381,640 1920 1968 2000 2080 1080 1083 1093 1112 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
EIA/CEA/CTA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080p at 144Hz (16:9)
Modeline............... "1920x1080" 356,390 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #2....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
1920 x 1080p at 120Hz - HDTV (16:9, 1:1)
1920 x 1080p at 100Hz - HDTV (16:9, 1:1)
1280 x 720p at 100Hz - HDTV (16:9, 1:1)
1280 x 720p at 120Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
Report information
Date generated........... 16/09/2023
Software revision........ 2.91.0.1043
Data source.............. Real-time 0x0100
Operating system......... 10.0.22621.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,2D,F4,00,27,00,00,00,00,2C,1E,01,04,A5,3C,21,78,3B,CA,75,A9,54,45,98,22,
1F,50,54,A5,4B,00,71,40,81,C0,81,80,95,00,A9,C0,B3,00,D1,C0,01,01,14,95,80,A0,70,38,20,40,30,20,
3A,00,BA,89,21,00,00,1E,00,00,00,FD,00,30,A5,B4,B4,2D,01,0A,20,20,20,20,20,20,00,00,00,FC,00,58,
47,4D,32,37,52,47,42,46,0A,20,20,20,00,00,00,FF,00,20,20,20,20,20,20,20,20,20,20,20,20,0A,01,20,
02,03,1B,F1,4E,90,05,04,03,02,01,1F,13,12,11,3F,40,29,2F,23,09,07,07,83,01,00,00,37,8B,80,18,71,
38,2D,40,58,2C,45,00,BA,89,21,00,00,1E,02,3A,80,18,71,38,2D,40,58,2C,45,00,BA,89,21,00,00,1E,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,28
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI00018.PCI0001C
00000000 = 3EC28086.20900006.06000007.00000000.00000000.00000000.00000000.00000000
00000008 = 19018086.00100407.06040007.00810010.00000000.00000000.00010100.2000E0E0
000000A0 = A2AF8086.02900406.0C033000.00800000.FFF10004.0000002F.00000000.00000000
000000B0 = A2BA8086.00100406.07800000.00800000.FFFEB004.0000002F.00000000.00000000
000000B8 = A2828086.02B00407.01060100.00000000.F7204000.F7207000.0000F051.0000F041
000000E0 = A2948086.00100404.060400F0.00810010.00000000.00000000.00020200.200000F0
000000E7 = A2978086.00100407.060400F0.00810010.00000000.00000000.00030300.2000D0D0
000000E8 = A29A8086.00100404.060400F0.00810010.00000000.00000000.00040400.200000F0
000000F8 = A2CA8086.02000007.06010000.00800000.00000000.00000000.00000000.00000000
000000FA = A2A18086.00000000.05800000.00800000.F7200000.00000000.00000000.00000000
000000FB = A2F08086.00100006.04030000.00002010.FFFEC004.0000002F.00000000.00000000
000000FC = A2A38086.02800003.0C050000.00000000.FFF24004.0000002F.00000000.00000000
00000100 = 21C410DE.00100007.030000A1.00800010.F6000000.E000000C.0000002F.F000000C
00000101 = 1AEB10DE.00100006.040300A1.00800010.F70FC000.00000000.00000000.00000000
00000102 = 1AEC10DE.00100406.0C0330A1.00800010.F200000C.0000002F.00000000.F204000C
00000103 = 1AED10DE.00100406.0C8000A1.00800010.F70FB000.00000000.00000000.00000000
00000300 = 816810EC.00100406.02000015.00000010.00000001.00000000.F7104004.00000000
Report information
Raw data
Hardware data
