Ensambladores 980Ti
xxtonixx
25 Feb 2015
Yo la verdad es que no conocia la zotac y estaba en tu situacion, decidiendo entre la MSI y la G1, pero viendo la zotac... viene muy subida no? Tiene un pintón tremendo
Las Inno, GALAX/HOF son las más brutitas.
Te traigo un quote de OCN:
1- Reference Cards.
1000
These come from Nvidia directly and usualy the first thing to be released to all vendors. Vendors have all ready put there custom coolers and some have played with the clocks too.
PCB Shots:
1000
1000
VRM: 6+2
Power Pins: 8+6
Voltage Controller: NCP8114
Bios: 1000mhz on Core, 1078 boost.
Custom Bios Avaliable: YES
Waterblocks: AVALIABLE - EKWB
2- Gigabyte GTX 980 Ti G1 Gaming
1000
First custom PCB to be released and actually a pretty good one too! The original Air cooler is a beast and extremely good.
PCB Shots:
1000
1000
VRM: 8
Power Pins: 8+8
Bios: 1152mhz on Core, ~1350mhz boost.
Custom Bios: Avaliable, but nothing seems to be better than stock.
Waterblocks: Soon™- EKWB
3- MSI GeForce GTX 980 Ti Gaming 6
1000
The MSI Gaming series is back and it's packing a bang as usual. The PCB is HUGE with a lot of good things to say about stability. The cooler is no slouch too and has excellent thermals and sound signature.
PCB Shots:
1000
1000
VRM: 10
Power Pins: 8+8
Bios: 1178mhz on Core, ~1400mhz boost.
4- EVGA GeForce GTX 980 Ti Classified
1000
EVGAs 980 ti Classified is the first 980 ti with an open voltage controller (until kingpin edition that is). The current avaliability of the card is reaching vaporware due to the high demand!
PCB Shots:
1000
1000
VRM: 14+3!
Power Pins: 8+8
Voltage Controller: Unknown for 980 ti. 780 Classy had CHiL 8318.
Bios: 1190mhz on Core, ~1400mhz boost.
Custom Bios: Avaliable on kingpin
Waterblocks: EKWB - Avaliable 780 Classy block fits (VISUAL not yet confirmed physical)
5- ASUS GeForce GTX 980 Ti STRIX
1000
ASUS GeForce GTX 980 Ti STRIX got some flak for having medicore cooling on launch even though the PCB seems packing.
PCB Shots:
1000
VRM: 12+2!
Power Pins: 8+8
Voltage Controller: Seems to have CHiL 8318. Need confirmation
Bios: 1190mhz on Core, ~1317-1400mhz boost.
Custom Bios: Unknown at this time.
6- KFA² GeForce GTX 980 Ti HOF
1000
The first all white 980 ti I have seen and looks simply awesome. There's an 8-Pack LN version incoming too!
PCB Shot:
1000
VRM: I counted 11+3 but the official specs show 8+2.
Power Pins: 8+8
Voltage Controller: Officially IR3555.
Bios: 1190mhz on Core, ~1291-1400mhz boost.
Waterblocks: No Full Blocks.
7- Zotac GeForce GTX 980 Ti AMP! Extreme
1000
As far as I know, Zotac was the second with a custom PCB for the 980 ti to be released to the public. With a strong cooling and decent PCB it was a fair shot at the masses. Only gripe it was a 3-slot cooling on launch.
PCB Shots:
1000
VRM: 11+2
Power Pins: 8+8
Voltage Controller: Can't find a source.
Bios: 1253mhz on Core, ~1317-1355-1400mhz boost.
8- Colorful GeForce GTX 980 Ti iGame Ymir-X
1000
For those who don't know Colorful. They are the Asus of the chinese market. And their PCB is packing! Only other 980 ti with a dual bios switch (Classified being the other)
PCB Shots:
1000
VRM: 14!
Power Pins: 8+8
Voltage Controller: No info.
Bios: 1127mhz on Core, ~1216mhz boost. (Very Mild)
Waterblocks: No Full Waterblocks.
Aunque haya quien no quiera mirárselo en ingles, al menos información de fases y relojes se entiende.
Gigabyte con la G1 se ha aprovechado del buen trabajo que hizo en las 970 y 980 y en ser la primera en tener disponible una 980 Ti de custom PCB, y ha vendido como churros. Y es una muy buena gráfica, sin duda alguna.
No obstante, hay otras que son "más brutas"...
Ahora hay que buscarlas por el mercado accesible desde nuestro país y comprar precios para ver si merece la pena el sobrecoste de unas a otras.
Justo iba a subir info de ese articulo.por eso me gusta la Zotac
A ver, es que las Inno no vienen tan subidas. La G1 si. Lo de las RMAs donde lo has visto? Es que se pone en base a unos 1300... es una burrada, y la memoria la sube hasta unos 7200, viene muy fuertecilla
Miento, no en base, en boost. Me equivoque, pero vamos, que viene muy muy subida, por eso me llama... me has dado miedo con las RMAs vmo igual es como lo de la luz de la muerte en ps4, cosa de las primeras hornadas
Ahora mismo estoy en espera de llegar la msi 980ti con cooler de referencia
Como lo voy a tener lo voy a prezentar en foro
Enviado desde mi GT-N7100 mediante Tapatalk
Ahora lo acabo de encontrar: inestabilidad de la gráfica (aunque no tenga OC), artifacts, que la gráfica de repente cae en rendimiento con los mismos drivers, y probando otra GPU esa va bien y la Zotac no... Y eso con cualquier modelo (sea 550Ti, 770, 980...).
