Kutulu1980
- 1 May 2017
acabo pasar el memory test a mis rams, y me dieron los siguientes resultados.
11/10/2017 MemTest86-Report-20171011-005123.html
Summary
Report Date 2017-10-11 04:39:17
Generated by MemTest86 V7.4 Free (64-bit)
Result FAIL
System Information
EFI Specifications 2.50
System
Manufacturer System manufacturer
Product Name System Product Name
Version System Version
Serial Number System Serial Number
BIOS
Vendor American Megatrends Inc.
Version 0902
Release Date 09/08/2017
Baseboard
Manufacturer ASUSTeK COMPUTER INC.
Product Name PRIME X370-PRO
Version Rev X.0x
CPU Type AMD Ryzen 5 1600X Six-Core
CPU Clock 3743 MHz [Turbo: 3743.3 MHz]
# Logical Processors 12
L1 Cache 12 x 96K (60452 MB/s)
L2 Cache 12 x 512K (57909 MB/s)
L3 Cache 1 x 16384K (28763 MB/s)
Memory 16331M (16847 MB/s)
DIMM Slot #0 8GB DDR4 XMP PC4-19200
G Skill Intl / F4-2400C15-8GFT
15-15-15-39 / 2400 MHz / 1.200V
DIMM Slot #1 8GB DDR4 XMP PC4-19200
Result summary
Test Start Time 2017-10-11 00:51:23
Elapsed Time 3:45:23
Memory Range Tested 0x0 - 41F380000 (16883MB)
CPU Selection Mode Parallel (All CPUs)
ECC Polling Enabled
# Tests Passed 27/48 (56%)
Lowest Error Address 0x1AF630280 (6902MB)
Highest Error Address 0x246CA93A0 (9324MB)
Bits in Error Mask 0000000021F1FF60
Bits in Error 17
Max Contiguous Errors 1
Test # Tests Passed Errors
Test 0 [Address test, walking ones, 1 CPU] 4/4 (100%) 0
Test 1 [Address test, own address, 1 CPU] 4/4 (100%) 0
Test 2 [Address test, own address] 4/4 (100%) 0
Test 3 [Moving inversions, ones & zeroes] 4/4 (100%) 0
Test 4 [Moving inversions, 8-bit pattern] 1/4 (25%) 6
Test 5 [Moving inversions, random pattern] 1/4 (25%) 48
Test 6 [Block move, 64-byte blocks] 0/4 (0%) 342
Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 317
Test 8 [Random number sequence] 0/4 (0%) 82
Test 9 [Modulo 20, ones & zeros] 1/4 (25%) 10
Test 10 [Bit fade test, 2 patterns, 1 CPU] 4/4 (100%) 0
Test 13 [Hammer test] 4/4 (100%) 0
Last 10 Errors
[Data Error] Test: 9, CPU: 8, Address: 20F47ABCC, Expected: F5F4F70A, Actual: F5F4D70A
[Data Error] Test: 9, CPU: 3, Address: 1F9CD8CBC, Expected: DAF2196C, Actual: DAF2396C
[Data Error] Test: 9, CPU: 8, Address: 20E63BE8C, Expected: 250DE693, Actual: 250DC693
[Data Error] Test: 8, CPU: 8, Address: 23DD697E0, Expected: 2CDDB0F0, Actual: 2CFDB0F0
[Data Error] Test: 8, CPU: 7, Address: 23A229BE0, Expected: C08CD1DB, Actual: C0ACD1DB
[Data Error] Test: 8, CPU: 8, Address: 20E97A7CC, Expected: 9244DE07, Actual: 9244FE07
[Data Error] Test: 8, CPU: 9, Address: 210453444, Expected: A7612D05, Actual: A761AD05
[Data Error] Test: 8, CPU: 6, Address: 207D12C04, Expected: 9ADF8035, Actual: 9ADF0035
[Data Error] Test: 8, CPU: 8, Address: 20F73BE8C, Expected: 7B02DBAA, Actual: 7B02FBAA
[Data Error] Test: 8, CPU: 8, Address: 20E27BF8C, Expected: 29C66795, Actual: 29C64795
me mosquean esos errores, y desde que tengo el pc, siempre me ha dado problemas, ahora las memorias las tengo tal como indica mi firma.
Summary
Result FAIL
System Information
System
BIOS
Version 0902
Baseboard
Version Rev X.0x
Result summary
ECC Polling Enabled
Bits in Error 17
Last 10 Errors
