Danyelcm
Chapuzas sin vida social
- 30 Ago 2016
¿Notas holgura en ese interruptor? Se mueve? ¿Cambia con click o se desliza?Nada :snif::snif:
Pues es un parche lo que estás haciendo, y como pone ahí, después te volverá a pasar, tramita el RMA que eso es un problema gordo, y de paso, pillas una Gigabyte o Asus, a mí personalmente, en lo que a placas base se refiere, MSI no me inspira confianza (He tenido varios problemas), repito, "Personalmente".Solucionado Danyelcm y peraltica7
Con esto sacado de aqui:
MSI Z170A Gaming M3 Capped at 800 MHz
BD PROCHOT stands for bi-directional processor hot. This allows other sensors on your motherboard to signal the CPU which forces the CPU to use the minimum multiplier (8). The CPU behaves exactly the same as if it was thermal throttling but in this case, the CPU temperature is fine. On some motherboards, it can be either a temperature switch from the voltage regulator or a power consumption switch. On your motherboard, it is very likely that the Slow Mode switch intended for LN2 users is failing. The only fix is a new board. This problem has nothing to do with Windows.
ThrottleStop is the only free software available that lets a user disable the BD PROCHOT signal path. When you uncheck BD PROCHOT, that blocks signals from the defective switch getting to your CPU. A simple fix and after you disable BD PROCHOT, you should be able to exit ThrottleStop and the BD PROCHOT signal path will remain disabled. ThrottleStop also has an option that you can add to the INI configuration file.
ExitTime=5 Danyelcm , peraltica7
Al final esto es lo unico que me ha funcionado pero si el fallo viene del sensor de temperatura que hace que se proteja el procesador y la placa lo bloquee.
Lo he arreglado con este programa:
This option tells ThrottleStop to exit 5 seconds after it starts. ThrottleStop will start up, fix the problem and then quietly exit.
Why is ThrottleStop "not ideal"?
Use the Task Scheduler to add it to the Windows start up sequence and you will not have to worry about this issue. If you use stand by mode, you might have to run ThrottleStop again after you resume. When properly setup, it is a very efficient program so some users prefer to leave it running, minimized to the system tray.
Con la opcion puesta:
Con la opcion quitada:
Pero creo que voy a pedir RMA, que opinais?
Bueno, a ver qué te dicen.
Abrazos!
Ahora ya son casi normales igual un pelín le falta al procesador pero ya está en valores normales. Pide cambio de placa que es un programa norma bastante gordoNo creo que me devuelvan el dinero para poder coger otra de otra marca, como mucho el cambio por otra mas moderna.
Dejo el nuevo benchmark:
MSI Z170A GAMING M7 (MS-7976) Performance Results - UserBenchmark
Hola, me quedé sobado XD. Rma, el cpu está capado por la placa, botón jodido si lo hay, o placa defectuosa (sensores?). Como dice Danyelcm Msi.. buff, (experiencia personal con alguna placa)este mes hemos visto bastantes problemas en placas de este fabricante y un par de ellas por el mismo caso que el tuyo. Asus o Gigabyte me inspiran más confianza por experiencia personal, saludos y suerte.Solucionado Danyelcm y peraltica7
Hola de nuevo a todos, os dejo con la ultima actualizacion a pesar de que ya haya pedido el RMA.
Instalando la version de la bios 1.9 que fue previa a la actualizacion para el soporte de los nuevos procesadores si que funciona el desactivar el Intel Adaptive Thermal Monitor por si le sirve a alguien de ayuda en un futuro.
Muchas gracias a todos!
