Miniji5
- 6 Mar 2014
:tititi::tititi::tititi: l don't know if this is okay..:demonio::demonio::demonio:
WTF?? All Chinese ads are awesome :memeo::memeo:
:tititi::tititi::tititi: l don't know if this is okay..:canta::canta::canta:
That's so funny hahaha.
By the way I still waiting for some coupons :canta::tititi::gayfight::sehseh::ñeñe:....
Hello!
Can you recomend me any mobile with touchscreen of 4" and not too expensive? around 60/70€...
Thanks and regards![]()
:bailarin: no prob...coupons are waiting for you~~~~~~~~~~
Hello!
Any better option for 110 euros (max) than umi x1 pro?¿
Im watching this 2 too:
http://es.coolicool.com/thl-t5s-mtk...d-pantalla-android-42-3g-smartphone-g-1232473
http://es.coolicool.com/zopo-cuppy-...d-core-android-42-qhd-3g-smartphone-g-1232350
But they have less resolution. Btw they have better camara.
I dont know really which one will go better.
Any advice¿?
Any advice¿?
apanoelfeliz: l got lots of ads like these hahha~~~
well maybe l will publish some of them if you come here to talk with me..often or ....always...hahahah
Any advice¿?
Actually, my name is Sarutobi Hiruzen. l'm from 木ノ葉.inocho:
Hello friend!
Leslie brings 8 cellphones to you!
:roto2gaydude: Come and have a look!
Cellphones with 4'' screen
http://es.coolicool.com/cubot-c9w-m...ntalla-umts3g-android-42-smartphone-g-1232390
http://es.coolicool.com/lenovo-a369...a-pantalla-android-42-3g-smartphone-g-1232461
http://es.coolicool.com/lenovo-a390...e-40-pulgadas-android-40-smartphone-g-1232456
http://es.coolicool.com/doogee-dg10...s-ips-android42-smartphone-dual-sim-g-1232511
http://es.coolicool.com/xiaocai-x80...2-4-pulgadas-fwvga-pantalla-3gphone-g-1232408
these phones are good too..
http://es.coolicool.com/jiake-i9500...droid-42-smartphone-dual-sim-umts3g-g-1232297
http://es.coolicool.com/catee-ct100...a-pantalla-android-42-3g-smartphone-g-1232542
http://es.coolicool.com/mtk6572-dua...ntalla-dual-sim-dual-camara-um-ts3g-g-1232329
if you still have any questions, welcome to discuss with us! :ñeñe:
Best regards
Leslie Lee
Ok! Then, there i am. I want a Chinese ad now! :tuvieja:
Te añado otra opción más económica que el THL:
http://es.coolicool.com/elephone-p7...d-pantalla-android-42-3g-smartphone-g-1232534
Comentar que no tiene led de notificaciones y multitouch de 2 puntos (me jugaría la mano que el THL también). Ojo con las características que ponen en la tienda porque no son exactas al menos para los modelos que yo conozco.
El elephone lo tengo yo. Decir que el mio vino con un problema de ROM que hacía que se bloqueara la pantalla por culpa del sensor de proximidad y si miras en htcmania algunos han venido con problemas de reinicios. Si os ocurre se soluciona fácil instalando la rom del mlais mx28 de enero.
Ventajas: Pantalla 5 pulgadas, muuuuy fluido, excelente batería de 2500mah, batería
Pegas: Baja cobertura de wifi aunque en mi caso donde la uso es suficiente (se puede arreglar haciendo apaños), multitouch 2 puntos (yo no juego, me importa un pimiento), táctil regulero
Si a alguien le interesa más información sobre el móvil lo decís.
PD: el UMI x1 pro tiene muy buena pinta aunque no hay mucha información al respecto de ese teléfono, hay otro exactamente igual de la marca dodgee
Si a alguno le interesa
jajajajaja and Im from 雨隠れの里 jajaja Im 五代目风影, but you can name 我愛羅 :sehseh: jajajajainocho:
I dont know chinese but yes something of japanese xD
Thanks so much!!!!
ありがとう。
私は少し日本語を知っている。
バッ テリーは交換可能です? ---> http://es.coolicool.com/xiaocai-x80...2-4-pulgadas-fwvga-pantalla-3gphone-g-1232408
When will arrive the Jiayu f1 with WDCMA, 3g? And the Jiayu g2f? (better in English jajaja my japanesse is worse)
Regards Leslie Lee-Kun![]()
