sarewak
- 4 Dic 2013
Hola a todos.
Actualmente esta es mi configuración de equipo:
I7 950 3.06@4.00 Ghz
Noctua NH-D14 (por aire)
Placa base Gigabyte UD-3R
6 Gb Memoria RAM (Triple Channel)
Gráfica Amd R9 390x
F.A. Enermax Platimax 850w
Y estos los parámetros de overclock de la BIOS (ya que subí a 4.00 Ghz):
MB Intelligent Tweaker(M.I.T.)
CPU Clock Ratio............................: 20
CPU Frequency .....(Mhz)...................:4,000 Ghz
Advanced CPU Features [Press Enter]
Intel(R) Turbo Boost Tech.................:[Disabled]
CPU Cores Enabled...........................:[All]
CPU Multi Threading.........................:[Enabled]
CPU Enhanced Halt (C1E)..................:[Disabled]
C3/C6/C7 State Support...................:[Disabled]
CPU Thermal Monitor........................:[ Enabled]
CPU EIST Function...........................:[ Disabled]
Bi-Directional PROCHOT.....................:[Enabled]
QPI Clock Ratio*...............................: Auto
QPI Link Speed* ...............................(Ghz): 7,2 Ghz
Uncore Clock Ratio............................. x16
Uncore Frequency..............................(Mhz): 3200 Mhz
Isochronous Support.........................:[Enabled]
Virtualization Technology...................:[Enabled]
>>>>>Standard Clock Control
Base Clock (BCLK) Control*.................:[ Enabled]
BCLK Frequency (Mhz)*......................:200
Extreme Memory Profile (X.M.P.)............:[Disabled]
System Memory Multiplier (SPD).............: x8
"Memory Frequency (Mhz) 1600
PCI Exxpress Frequency (Mhz)...............:[100]
>>>>>Advanced Clock Control
CPU Clock Drive (mV).......................:[800]
PCI Express Clock Drive (mV)..............:[900]
CPU Clock Skew (ps)........................:0
IOH Clock Skew (ps)........................:0
Advanced Memory Settings [Press Enter}
System Memory Multiplier (SPD).............:[x8]
"Memory Frequency (Mhz) 1600 1600"
Performance Enhance........................:[Standard]
DRAM Timing Selectable (sPD) ..............:[Auto]
Channel Interleaving.......................:6 [auto]
Rank Interleaving..........................:4 [auto]
>>>>>Channel A Standard Timing Control
Cas Latency Time.............................:8
tRCD.........................................:8
tRP..........................................:8
tRAS.........................................:24
>>>>>Channel A Advanced Timing Control
tRC..........................................:27 [38]
tRRD ........................................:4[Auto]
tWTR ........................................:4[Auto]
tWR..........................................:8[Auto]
tWTP.........................................:19[Auto]
tWL..........................................:7[Auto]
tRFC.........................................:60[88]
tRTP.........................................:4[Auto]
tFAW.........................................:20[Auto]
Command Rate (CMD) ..........................:1 [2]
>>>>>Channel A Misc Timing Control
B2B CAS Delay................................:-[Auto]
Round Trip Latency...........................:47[Auto]
Channel A Turnaround Setting [Press Enter]
>>>>> Channel A Reads Followed By Reads
Different DIMMs.............................. : 6 [Auto]
Different Ranks..............................: 5 [Auto]
On The Same Rank.............................:1 [Auto]
>>>>> Channel A Writes Followed By Writes
Different DIMMs..............................: 6 [Auto]
Different Ranks..............................: 6 [Auto]
On The Same Rank.............................: 1 [Auto]
Advanced Voltage Control [Press Enter]
>>>>CPU Voltages
LoadLine Calibration.........................:[STANDARD]
CPU Vcore....................................:1,262v
QPI/VTT Voltage..............................:1.355v*
CPU PLL......................................:1.880v [Auto]*
>>>>>MCH/ICH Voltrage
PCIE.........................................:1.50 v[Auto]
QPI PLL......................................:1.10v[Auto]
IOH Core.....................................:1.20v[Auto]*
ICH I/O......................................:1.50v[Auto]
ICH Core.....................................:1.10v[Auto]
>>>>>Dram
DRAM Voltage.................................:[1.65v]
DRAM Termination.............................:0.750v[Auto]
Ch-A Data Vref...............................:0.750v[Auto]
Ch-B Data Vref...............................:0.750v[Auto]
Ch-C Data VRef...............................:0.750v[Auto]
Ch-A Address Vref............................:0.750v[Auto]
Ch-B Address Vref............................:0.750v[Auto]
Ch-C Address VRef............................:0.750v[Auto]
_____________________________________________________________
El tema es que me quiero ampliar la memoria RAM ya que estoy usando programas de corrección de color y con 6 Gb voy muy muy justo, y a veces me da fallos. Uso Da Vinci Resolve 12.5, que recomiendo al menos 16 Gb.
Por tema de posibles incompatibilidades, había pensado en vender mis módulos y comprar tres nuevos (sueltos), de 8 Gb, para así tener 24 Gb RAM, e ir sobrado.
Mi duda es que al cambiar de 6gb a 24gb, la configuración de mi overclock ya no sería válida, creo. Y es ver que es lo que debería de cambiar para no perder la establidad que tengo con dicha configuración.
Gracias de antemano y saludos.
Gráfica Amd R9 390x
>>>>CPU Voltages
>>>>>MCH/ICH Voltrage
>>>>>Dram
