Bajando algunos componentes se podría quedar en algo así:
Te dejo una solución:
>>>> Link directo a este presupuesto #0025677 <<<<
Está realizado en la tienda
http://www.aussar.es (ver
Has comprado en Aussar? ¡Muéstranos tu nuevo PC!)
[TABLE="class: std table-bordered, width: 55%"]
[TR]
[TH="class: cart_product first_item, align: center"]PRODUCTO[/TH]
[TH="class: cart_description item"]DESCRIPCIÓN[/TH]
[TH="class: cart_unit item, align: center"]PRECIO UNITARIO[/TH]
[/TR]
[TR="class: cart_item first_item address_8387 odd"]
[TD="class: cart_product, align: center"]
[/TD]
[TD="class: cart_description"]
SEAGATE BARRACUDA 7200.14 2TB SATA3[/TD]
[TD="class: cart_unit, align: right"]
66,99 €[/TD]
[/TR]
[TR]
[TD="class: cart_product cart_item first_item address_8387 odd, align: center"]
[/TD]
[TD="class: cart_description cart_item first_item address_8387 odd"]
CRUCIAL BX-200 240GB[/TD]
[TD="class: cart_unit cart_item first_item address_8387 odd, align: right"]
62,90 €[/TD]
[/TR]
[TR="class: cart_item address_8387 even, bgcolor: #F3F3F3"]
[/TD]
SEASONIC M12II EVO-620W 80PLUS BRONZE[/TD]
94,99 €[/TD]
[/TR]
[TR="class: cart_item address_8387 odd"]
[/TD]
COOLBOX LECTOR DE TARJETAS CR-600 USB 2.0[/TD]
12,00 €[/TD]
[/TR]
[/TD]
CRYORIG H7[/TD]
35,50 €[/TD]
[/TR]
[/TD]
MSI GEFORCE GTX970 4GD5T OC 4GB DDR5[/TD]
310,00 €[/TD]
[/TR]
[/TD]
INTEL CORE I7- 6700K 4.0GHZ[/TD]
327,00 €[/TD]
[/TR]
[/TD]
GIGABYTE Z170-HD3P[/TD]
112,00 €[/TD]
[/TR]
[/TD]
G.SKILL RIPJAWS V RED DDR4 2400 16GB 2X8GB CL15[/TD]
66,00 €[/TD]
[/TR]
[/TD]
NOX HUMMER ZX ZERO EDITION[/TD]
56,00 €[/TD]
[/TR]
[TR="class: cart_item address_8387 even last_item, bgcolor: #F3F3F3"]
[/TD]
LG GRABADORA DVD-RW GH24NSD1 OEM[/TD]
14,00 €[/TD]
[/TR]
[TR]
[TD="class: cart_product cart_item address_8387 even last_item, align: center"][/TD]
[TD="class: cart_description cart_item address_8387 even last_item"]
Total de productos (IVA incluído):[/TD]
[TD="class: cart_unit cart_item address_8387 even last_item, align: right"]
1.157,38 €[/TD]
[/TR]
[TR]
Total de envío (IVA incluído):[/TD]
11,99 €[/TD]
[/TR]
[TR]
[TD="class: cart_description cart_item address_8387 even last_item, align: right"]
Total[/TD]
1 169,37 €
[/TD]
[/TR]
[/TABLE]
Oncircle @
ripa72
Me parece bastante bien la propuesta lo único que me estoy mirando alguna caja ATX mas baratilla y así implementar por ejemplo el disco duro de 1 TB a 2TB.
Me gustaria saber si me podeis aclarar porque me han dicho que el ordenador con lo que consume la gráfica y todos los elementos en pleno rendimiento alomejor me quedo un pelin justillo con la fuente .
Y he estado mirando fuentes y la plus gold de 650 W creo que era salia por unos 10 euros más , me gustaria saber si me la recomendais y la diferencia de gold a bronze o si con la bronze de 620W tengo de sobra.
Muchas gracias,
Lo importante son los amperios que rinde la PSU y no tanto la potencia nominal. Una 650W puede tener menor amperaje que una 620W dependiendo esto más de la calidad de la PSU. La
SEASONIC M12II EVO-620W 80PLUS BRONZE rinde 48A / 576W en el carril de +12V. Tu construcción gasta en torno a los 350W (ver
http://outervision.com/b/9ZC46k) y si además dices que no vas a hacer OC, te queda una remanente de 276W, suficiente para actualizar a cualquier GPU futura. Realmente con 550W ya te valdría pero yo soy partidario de mayor margen de potencia de cara a futuras actualizaciones y porque la PSU trabajará menos estresada la mayor parte del tiempo. Y las diferencias de precio son escasas.
Si quieres algo más eficiente y potencia podríamos irnos a la
CORSAIR RM650X 80PLUS GOLD que rinde 54A / 648W en el rail +12V. Una gran fuente sin duda.
