Ajustando Undervolt en Ryzen 9 3900X (ayuda)
Vale, si yo prefiero dejarlo fino por la bios la verdad, es mas que nada saber como lo haceis, que pasos seguir o algun video tutorial.
esto me acaba de dar el CTR a 1200 de voltage y frecuencia de referencia a 4000.
***ClockTuner for Ryzen 2.1 RC5(ver.23) by 1usmus***
AMD Ryzen 9 3900X 12-Core Processor
ASUS PRIME X370-PRO
BIOS ver. 6042 SMU ver. 46.72.00
TABLE ver. 2361347
DRAM speed 3200 MHz
10/23/2022 13:07:13
P1
FREQ CCX1# 3950MHz
FREQ CCX2# 3950MHz
FREQ CCX3# 3900MHz
FREQ CCX4# 3925MHz
VID# 1150mV
Usage trigger# 81%
OB CCX1# 1
OB CCX2# 1
P2
FREQ CCX1# 0MHz
FREQ CCX2# 0MHz
FREQ CCX3# 0MHz
FREQ CCX4# 0MHz
VID# 1275mV
Usage trigger# 29%
OB CCX1# 1
OB CCX2# 1
PX
FREQ HIGH# 4475MHz
FREQ MID# 4400MHz
FREQ LOW# 4350MHz
VID HIGH# 1450mV
VID MID# 1425mV
VID LOW# 1400mV
OB HIGH# 1
OB MID# 1
OB LOW# 1
Usage trigger# 12%
PX OB LIMIT# 75MHz
Manual OC enabled: profile #1
Phoenix ready!
AVX Light mode
Cycle time: 360000 ms
Reference frequency: 4000 MHz
CCX delta: 150 MHz
Reference voltage: 1200 mV
Target voltage: 1200 mV
Manual overclocking mode enabled
18:21:25: Saving temporary settings...
Step# 1
18:21:30: CCX1 (156): 4125 MHz, 1200 mV OC=
18:21:30: CCX2 (145): 4125 MHz, 1200 mV OC=
18:21:30: CCX3 (134): 4000 MHz, 1200 mV OC+
18:21:30: CCX4 (122): 4000 MHz, 1200 mV OC+
18:21:31: Stress test #1 started...
18:21:35: CPU Vdroop: 2,6 % temperature: 52,1°
18:23:07: Stress test stopped.
18:23:08: Stress test #2 started...
18:23:12: CPU Vdroop: 2,6 % temperature: 54,3°
18:24:12: CCX3 overclocking failure detected!
18:24:12: Thread# 12 fall down!
18:24:12: Stress test stopped.
Step# 2
18:24:14: CCX1 (156): 4125 MHz, 1200 mV OC=
18:24:14: CCX2 (145): 4125 MHz, 1200 mV OC=
18:24:14: CCX3 (134): 3975 MHz, 1200 mV OC=
18:24:14: CCX4 (122): 4000 MHz, 1200 mV OC=
18:24:15: Stress test #1 started...
18:24:20: CPU Vdroop: 2,6 % temperature: 54,3°
18:25:51: Stress test stopped.
18:25:52: Stress test #2 started...
18:25:56: CPU Vdroop: 2,7 % temperature: 54,7°
18:27:27: Stress test stopped.
18:27:29: Stress test #3 started...
18:27:33: CPU Vdroop: 2,6 % temperature: 54,5°
18:29:05: Stress test stopped.
18:29:07: Stress test #4 started...
18:29:11: CPU Vdroop: 2,7 % temperature: 54,8°
18:30:42: Stress test stopped.
Step# 3
18:30:44: CCX1 (156): 4125 MHz, 1194 mV OC=
18:30:44: CCX2 (145): 4125 MHz, 1194 mV OC=
18:30:44: CCX3 (134): 3975 MHz, 1194 mV OC=
18:30:44: CCX4 (122): 4000 MHz, 1194 mV OC=
18:30:45: Stress test #1 started...
18:30:49: CPU Vdroop: 2,7 % temperature: 54,8°
18:32:21: Stress test stopped.
18:32:23: Stress test #2 started...
18:32:27: CPU Vdroop: 2,7 % temperature: 54,4°
18:33:09: CCX2 overclocking failure detected!
18:33:09: Thread# 11 fall down!
18:33:09: Stress test stopped.
Step# 4
18:33:12: CCX1 (156): 4125 MHz, 1194 mV OC=
18:33:12: CCX2 (145): 4100 MHz, 1194 mV OC=
18:33:12: CCX3 (134): 3975 MHz, 1194 mV OC=
18:33:12: CCX4 (122): 4000 MHz, 1194 mV OC=
18:33:13: Stress test #1 started...
18:33:17: CPU Vdroop: 2,6 % temperature: 53,8°
18:33:39: CCX2 overclocking failure detected!
18:33:39: Thread# 11 fall down!
18:33:39: Stress test stopped.
Step# 5
18:33:41: CCX1 (156): 4125 MHz, 1194 mV OC=
18:33:41: CCX2 (145): 4075 MHz, 1194 mV OC=
18:33:41: CCX3 (134): 3975 MHz, 1194 mV OC=
18:33:41: CCX4 (122): 4000 MHz, 1194 mV OC=
18:33:42: Stress test #1 started...
18:33:46: CPU Vdroop: 2,7 % temperature: 53,7°
18:35:17: Stress test stopped.
18:35:19: Stress test #2 started...
18:35:23: CPU Vdroop: 2,6 % temperature: 53,4°
18:36:55: Stress test stopped.
18:36:57: Stress test #3 started...
18:37:01: CPU Vdroop: 2,6 % temperature: 53,5°
18:38:32: Stress test stopped.
18:38:33: Stress test #4 started...
18:38:38: CPU Vdroop: 2,6 % temperature: 53,5°
18:40:09: Stress test stopped.
Penalties for the final profile: level 1
18:40:10: CCX1 (156): 4100 MHz, 1206 mV OC=
18:40:10: CCX2 (145): 4050 MHz, 1206 mV OC=
18:40:10: CCX3 (134): 3950 MHz, 1206 mV OC=
18:40:10: CCX4 (122): 3975 MHz, 1206 mV OC=
Cinebench R20 started
Cinebench R20 finished with result: 7109
Voltage: 1.206 V PPT: 116.4 W Temperature: 63.4°
Phoenix deactivated!
Bueno, le he pasado el test a OCCT con la configuracion de 1200 - 4000mhz mas o menos y me ha aguantado 10 minutos, es necesario meterle 30 min o una hora?
Hombre, yo creo que si, al menos unos 25-30 minutos.
Así te aseguras de tener la estabilidad necesaria.
Veo que usas Ryzen Master y que quieres calcar los valores a la bios, pero...
Viendo esos 1.15v de vcore...Que pruebas de estabilidad estas haciendole a la cpu y que programa estas utilizando para ello?.
Yo con ese programa poco le puedo ayudar, al igual que @O3M lo hago todo por bios. Aparte, prefiero hacerle OC fijo que variable.
Precisamente os he citado por eso mismo.
Porqué vosotros sois de OC y ajustes por BIOS, como yo.
Pero yo no tengo ni idea de AMD.
Gracias, pues voy a ver si puedo ajustar un pelín más bajando frecuencia ( 1170 mV y 3850mHz) y le paso media horita el occt.
Esto se tira una hora y pico ( el CTR ) con el voltaje a 1170 y no para, al final lo he detenido yo, lo estoy probando de varias maneras y me estoy agobiando muchísimo porque no hace otra cosa que crasear el OCCT ese.
No entiendo porque peta en occt y en ctr no lo hace, al final solo quiero pasar a la bios el undervolt que tenia esta mañana y creo que se ha desconfigurado todo...
Vale, después del calentón vuelvo a ser persona, si tal probaré más tarde de nuevo, no puede ser tan difícil.
En tu placa base Asus yo haria lo siguiente.
Te metes en la bios y buscas la opcion Ai Tweaker. En las opciones que te aparecen elige en Ai Overclock Tuner y en el desplegable elige D.O.C.P. y veras que aparecen otras opciones.
En D.O.C.P. si no te sale DDR4 3200..........pues despliegalo y eliges esa opcion, lo demas lo dejas en auto.
En CPU Core Ratio eliges la opcion Manual y especificas el valor 44 (que es igual a 4.4ghz).
Por ultimo en VDDCR Core Voltage eliges Manual y pones 1.25, lo demas lo dejas en auto.
Asi tendras la ram por bios a 3200, la cpu a 4.4ghz (lo que esta muy bien para un 3900 que llega en turbo a 4.6ghz) y el voltaje a 1.25.
Pulsas F10, aceptas los cambios y pruebas con OCCT y te olvidas de CTR que mejor y antes de cambiar nada en bios tendrias que desinstalarlo.
Y ya veremos si tocamos el pbo...
Gracias señor, eso quería saber, si este tipo de cosas las hice en 2017 pero ya ni me acuerdo...
las rams estan con D.O.C.P. a 3200mhz, eso ya lo puse hace unos dias.
vale, una vez realizado imagino que pasamos a mirar la estabilidad de todo, no?
El CTR lo tengo que deshabilitar obviamente.
Si, CTR fuera y despues de esos cambios en bios pues a testear con OCCT y con Cinebench para ver puntuacion de rendimiento.
Que en OCCT te sale ok en 30m minimo de prueba pues accedes a la bios y en VDDCR Core Voltage bajas de 1.25 a 1.24 y vuelta a testear.
Asi vas bajando el voltaje y nada mas que OCCT te reporte error pues ya sabes que has bajado demasiado y que tienes que volver al valor de voltaje anterior.
Es decir, si a 1.22v te da error pues te metes en bios y pones 1.23.
Y siempre muy pendiente de las temps.
Mira que me sale en la bios, por algun motivo no me deja cambiar lo de automatico.
Pon el cursor del raton encima de auto en CPU Core Ratio y escribe con el teclado 44 y le das a enter, lo mismo es que se cambia asi en tu bios.
Compi, acabo de llegar a casa del curro, si no te respondo en un buen rato es que....😉
Vale, era así, santa paciencia tienes compañero, tienes ganado el cielo.
He puesto 44 en CPU core ratio y en vddcr CPU voltage manual, me lleva abajo a vddcr CPU voltage overtide y ahí le he metido 1.25
Edit: a 44 me ha petado así que le he metido 38 y ya veremos cómo voy subiendo.
A que le llamas exactamente petar?
a pegao un chuscazo la imagen como reiniciandose, la tipica escena de peli que ves una linea en el centro de la pantalla y se reinicia el equipo, igualmente al ponerlo en 40 con ese voltaje veo que el test occt sube a 86 en menos de dos minutos asi que veo bastante inviable poder hacerlo.
Eso es petar digamos, no?
Pero a ver si te explica mejor...
Cuando y en que momento te ha hecho eso de la pantalla?
Si, disculpa.
He introducido los valores 44 y 1,25.
He reiniciado el ordenador y cuando se encendia a ocurrido eso en la pantalla como un pantallazo azul y se ha reiniciado de nuevo el pc.
A eso me refería con petar.
Ahora he introducido 38 y 1,15, le pasare un test para ver que tal va.
Definitivamente este Test es demasiado para mi cpu o disipador, he probado con configuracion de 3,8 ghz a 1,25 de voltaje pero da error continuamente, y las temperaturas ya eran altitas.
Lo he probado con esa frecuencia en 1,15- 1,18- 1,20 y este ultimo 1,25 y no hay manera de superarlo.
en mi humilde opinion.
lo que yo haria (ya que veo que es una cpu perrona 😂).
resetea a valores de fafrica la bios,para empezar de nuevo.
lo primero activa el xmp en las memorias (no se como se llama en bios asus).
lo dejas todo en auto,menos el voltage que le pones offsert negativo a -010 .(vas probando el pc ,que no te peta le pones 0,15 asi hasta que te pete y retrocedes al punto que te va bien.
NO,TE FIJES EN LOS PARAMETROS DE LA FOTO ,TU LO HACES POCO A POCO.
Buenas compi, esto seria para ver si pasa el occt?
