Esa placa base msi H110M PRO VD que comentas la tuve yo y no daba problemas es una placa base decente. Eso si tendrás que asegurarte que la gráfica que tiene es pci express.
Creo que sí! mira!
[TABLE="class: ms-rteTable-default"]
[TR="class: ms-rteTableHeaderRow-default"]
[TH="class: ms-rteTableHeaderFirstCol-default, colspan: 1"][/TH]
[TH="class: ms-rteTableHeaderOddCol-default, colspan: 1"]
AMD Radeon™
HD 6450 GPU[/TH]
[/TR]
[TR="class: ms-rteTableOddRow-default"]
[TH="class: ms-rteTableFirstCol-default, colspan: 1"]
Engine Clock[/TH]
[TD="class: ms-rteTableOddCol-default"]625 MHz[/TD]
[/TR]
[TR="class: ms-rteTableEvenRow-default"]
Memory[/TH]
[TD="class: ms-rteTableOddCol-default"]512MB-1GB DDR3/GDDR5[/TD]
[/TR]
Memory Clock[/TH]
[TD="class: ms-rteTableOddCol-default"]533-900 MHz (1.066-1.8 Gbps) or 800-900 MHz GDDR5 (3.2-3.6 Gbps[/TD]
[/TR]
Memory Bandwidth[/TH]
[TD="class: ms-rteTableOddCol-default"]8.5-12.8 GB/s (DDR3) or 25.6-28.8 GB/s (GDDR5)[/TD]
[/TR]
Single Precision Compute Power[/TH]
[TD="class: ms-rteTableOddCol-default"]200GFLOPs [/TD]
[/TR]
TeraScale 2 Unified Processing Architecture[/TH]
- 160 Stream Processing Units
- 8 Texture Units
- 16 Z/Stencil ROP Units
- 4 Color ROP Units
[/TD]
[/TR]
Bus Interface[/TH]
[TD="class: ms-rteTableOddCol-default"]PCI Express 2.1 x16 [/TD]
[/TR]
OpenGL 4.1 Support[/TH]
[TD="class: ms-rteTableOddCol-default"]Yes [/TD]
[/TR]
Image Quality Enhancement Technology[/TH]
- Up to 12x multi-sample and super-sample anti-aliasing modes
- Adaptive anti-aliasing
- Morphological anti-aliasing (MLAA)
- 16x angle independent anisotropic texture filtering
- 128-bit floating point HDR rendering
[/TD]
[/TR]
Cutting-Edge Integrated Display Support[/TH]
- Max resolution: 2560x1600 per display
- Multi-Stream Transport
- 21.6 Gbps bandwidth
- High bit-rate audio
- HDMI 1.4a with Stereoscopic 3D Frame Packing Format, Deep Color, xvYCC wide gamut support, and high bit-rate audio
Max resolution: 1920x1200
- Max resolution: 2048x1536
[/TD]
[/TR]
Integrated HD audio controller[/TH]
- Output protected high bit rate 7.1 channel surround sound over HDMI or DisplayPort with no additional cables required
- Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
[/TD]
[/TR]
AMD Technologies[/TH]
[TD="class: ms-rteTableOddCol-default"]AMD Eyefinity multidisplay technology[SUP]1[/SUP]
- Native support for up to 3 simultaneous displays
- Up to 4 displays supported with DisplayPort 1.2 Multi-Stream
- Independent resolutions, refresh rates, color controls, and video overlays
- Display grouping
- Combine multiple displays to behave like a single large display
AMD App Acceleration[SUP]2[/SUP]
- OpenCL™ 1.1 Support
- DirectCompute 11
- Accelerated video encoding, transcoding and upscaling[SUP]2,5[/SUP]
- UVD 3 dedicated video playback accelerator
- MPEG-4 AVC/H.264
- VC-1
- MPEG-2 (SD & HD)
- Multi-View Codec (MVC)
- MPEG-4 part 2 (DivX, xVid)
- Adobe Flash
- Enhanced Video Quality features
- Advanced post-processing and scaling
- Dynamic contrast enhancement and color correction
- Brighter whites processing (Blue Stretch)
- Independent video gamma control
- Dynamic video range control
- Dual-stream HD (1080p) playback support
- DXVA 1.0 & 2.0 support
AMD HD3D technology[SUP]4[/SUP]
- Stereoscopic 3D display/glasses support
- Blu-ray 3D support
- Stereoscopic 3D gaming
- 3rd party Stereoscopic 3D middleware software support
AMD PowerPlay™ power management technology[SUP]3[/SUP]
- Dynamic power management with low power idle state
AMD Catalyst™ software and HD video configuration software
- Unified graphics display drivers
- Certified for Windows 7, Windows Vista, and Windows XP
- AMD Catalyst[SUP]TM[/SUP] Control Center
- Software application and user interface for setup, configuration, and accessing special features of AMD Radeon products.
[/TD]
[/TR]
[/TABLE]
