Creo que a mi tambien me ha sacado -30
***HYDRA 1.2H PRO by 1usmus***
01/21/2023 15:39:28
Creating a basic configuration file for settings...
Creating a basic configuration file for CPU profiles...
AMD Ryzen 7 5700X 8-Core Processor Stepping 2
MSI MAG B550 TOMAHAWK (MS-7C91) BIOS A.B0 SMU 56.70.00
TABLE ver.3672325
DRAM speed 3200 MHz
Auto VID search mode is used!
Target PPT value: 142W
Target EDC value: 140A
Target TDC value: 95A
Target THM value: 75°C
Target FIT value: 1
18:36:43: The process of forming a core rating has begun!
18:37:21: The core ranking process is complete...
18:37:21: The process of creating the 1T-4T profile has begun!
18:37:36: Finding the optimal VID in accordance with the target values...
Optimal VID found: 1151mV
18:37:38: Determining the optimal frequencies for group of the cores...
The process of determining the optimal frequencies is complete!
Results:
VID: 1151mV
CCD1 FREQUENCY: 4475MHz
18:37:40: Filling in the tables by the obtained results...
18:37:40: 1T-4T profile successfully created!
18:37:40: The process of creating the 5T-12T profile has begun!
18:37:55: Finding the optimal VID in accordance with the target values...
Optimal VID found: 1219mV
18:37:56: Determining the optimal frequencies for group of the cores...
Results:
VID: 1219mV
CCD1 FREQUENCY: 4600MHz
18:37:58: Filling in the tables by the obtained results...
18:37:58: 5T-12T profile successfully created!
18:37:58: The process of creating the ALL (AVX2) profile has begun!
18:38:13: Finding the optimal VID in accordance with the target values...
Optimal VID found: 1221mV
18:38:19: Determining the optimal frequencies for group of the cores...
Results:
VID: 1221mV
CCD1 FREQUENCY: 4650MHz
18:38:21: Filling in the tables by the obtained results...
18:38:21: ALL (AVX2) profile successfully created!
18:38:21: The process of creating the ALL (FMA3) profile has begun!
18:38:25: Finding the optimal VID in accordance with the target values...
Optimal VID found: 1097mV
18:38:27: Determining the optimal frequencies for group of the cores...
Results:
VID: 1097mV
CCD1 FREQUENCY: 4525MHz
18:38:29: Filling in the tables by the obtained results...
18:38:29: ALL (FMA3) profile successfully created!
18:38:29: The process of creating the ALL (GAME) profile has begun!
18:38:32: Finding the optimal VID in accordance with the target values...
Optimal VID found: 1194mV
18:38:33: Determining the optimal frequencies for group of the cores...
Results:
VID: 1194mV
CCD1 FREQUENCY: 4825MHz
18:38:36: Filling in the tables by the obtained results...
18:38:36: ALL (GAME) profile successfully created!
18:38:36: The process of creating the CUSTOM#1 profile has begun!
18:38:39: Determining the optimal frequencies for group of the cores...
Results:
VID: 1100mV
18:38:40: Filling in the tables by the obtained results...
18:38:40: CUSTOM#1 profile successfully created!
18:38:40: The process of creating the CUSTOM#2 profile has begun!
18:38:43: Determining the optimal frequencies for group of the cores...
Results:
VID: 1100mV
18:38:45: Filling in the tables by the obtained results...
18:38:45: CUSTOM#2 profile successfully created!
18:38:45: The process of finding the maximum single-threaded frequency has begun!
18:39:00: Determining the optimal frequencies for each of the cores...
C01 LIMIT: 4725MHz
C02 LIMIT: 4800MHz
C03 LIMIT: 4675MHz
C04 LIMIT: 4650MHz
C05 LIMIT: 4750MHz
C06 LIMIT: 4725MHz
C07 LIMIT: 4675MHz
C08 LIMIT: 4775MHz
18:39:17: Filling in the tables by the obtained results...
