Zen ryzen
Acabo de leer en EOL que han conseguido subir un ryzen 5 1600X a 5,9 GHZ por nitrógeno líquido y que a roto varios records...
Enviado desde mi P6000 Pro mediante Tapatalk
SI lo hubieras leido aquí antes, tambien lo hubieras sabido xD
Roman hizo una valiadation a 5.9Ghz, pero realmente son bencheables a 5.4Ghz
Por cierto, para la Hero:
elmor dijo:
Test BIOS 0079
Test BIOS with new AGESA 1004a, with a couple of bugfixes. Up to 5% performance increases in specific applications. Also has P-state overclocking working with BCLK increase. If you want to keep C-states, make sure to set Advanced\AMD CBS\Zen Common Options\Global C-state Control = Enabled. There are two new settings under AMD CBS\UMC Common Options\DDR4 Common Options\ you might want to take a look at, Fail_CNT and ProcODT. Fail_CNT decides how many times to retry when DRAM training fails (F9 -> 0d), default is now 1. ProcODT can help improve your DRAM overclocking. There's a setting available also on previous BIOSes under AMD CBS\UMC Common Options\DRAM Memory Mapping named BankGroupSwap. If you have 2x Single-Rank modules you can try setting this to Disabled and you might see some performance boost in certain applications.
Test BIOS 0081
Same as 0079 but has ProcODT default = 53.3 ohm
Test BIOS 0082
Same as 0081 but with a DRAM compability patch for the below part numbers
CMK16GX4M4A2133C13
AHU08GGB13CGT7G
PV416G240C5QK
F4-2400C15Q-32GRR
TCD44G2400C14BK
F4-2666C16Q2-64GRB
AVD4UZ126661504G
BLT8G4D26AFTA.16FAD
IMA41GU6MFR8N-C F0
MD16GK4D4266615AXR
HX430C15PB2K4/16
HX430C15PBK4/32
AX4U3333W4G16-QGZ
GAM4DBLBM2133D15IE041C
TC48G24S817
SP004GBLFU213N02
78.C1GM3.AF10B
F4-3200C16D-8GVKB
MTA4ATF51264AZ-2G6B1
MTA8ATF1G64AZ-2G3B1
MTA16ATF2G64AZ-2G6B1
HMA41GU7AFR8N-TF T0
HMA451U7AFR8N-TF T0
HMA41GU6AFR8N-UH N0
M378A2K43BB1-CTD
M378A1K43BB1-CRC
M378A1G43EB1-CRC
Test BIOS 0083
Same as 0079 but with "2T" DRAM Mode when using above 2666 DRAM Ratio.
Las mías a 3200 da pantallazos azules, a 2933 funcionan perfectamente
Si si, en mi caso igual. Pita varias veces y luego arranca con las memorias a 2133, reconfiguro y listo. Todavía no he tenido que hacer clear cmos.
Pd: Interesante tu solución.
Si, mas que nada porque ​al tener el CrossfireX me queda muy poco espacio para meter un destornillador largo y linterna, así que de rodillas (Y hasta los Webs de pegarme el curro fijo de dar con los dos pines) se me ocurrió hacer un extensor jaja
Bueno chicos tengo buenas noticias... me vais a perdonar pero soy muy ignorante con el tema de memorias, OC y tal, se lo que se y ya esta.... me habeis salvao la vida entre todos vosotros por que yo ya pensaba que habia cometido una estupidez de comprar memorias de 3200 Mhz aunque fueran compatibles con la placa pero de momento solo con 2 sticks.. pero viendo todo lo que poniais que si ponia este timings y tal y cual la memoria subia mas o bajaba etc etc y me ha venido a la cabeza de golpe hacer una cosa y es bajarme la tabla de compatibilidad de memoria de mi placa y he cojido y he dicho vamos a ver... vamos a mirar hasta que frecuencia maxima acepta mi placa con 4 sticks de ram depende del modelo de cada modulo en mi caso es de 8Gb cada uno y he visto... 2800Mhz Downgrade at 2666 Mhz y a continuacion ponia los timmigs a configurar que era 14-16-16-16-36 1,35V lo he puesto.... y ahora estan funcionando estable a 2666 Mhz mis 4 sticks :( no se que habria sido sin vuestos comentarios escritos aqui, gracias por ayudarnos a todos los que entendemos poco del tema este de modificar valores y todo eso. Ahora la latencia me ha bajado una brutalidad de 135ns a 86ns aqui os pongo una imagen, muchas graciass crackss!!!
He intentado actualizar la nueva bios en la placa asus x370 prime me dio error, reinicie y e pc enciende pero no detecta pantalla ni hace nada. Me tocara comprarme una nueva placa lol
no se como funcionaran esas placas pero creo que hay un metodo para recuperarla por medio de meter la BIOS en un USB y supongo que haciendo algo para que se quede en modo flash y flasheé la BIOS.... hablo un poco de mi ignorancia por que por ejemplo la mia que es la Gigabyte tiene Dual BIOS y si se flashea mal una, entra la otra que esta bien.
Usb flashback, lee el manual porque un puerto usb es para actualizar bios con el pc apagado (fuente conectada)
En mi asus es el puerto usb verde
Mi placa no trae ese tipo de usb, o por lo menos no lo veo, pero es raro porque el pc enciende pero el teclado no se detecta, y la pantalla pone no signal detected, le he quitado la pila a la placa etc pero nada
Pilla un pendrive, lo formateas en Fat32, bajas y metes la Bios 515 (Hazlo con otro PC).
Según esto:
la placa debería empezar a buscar en todos los USB hasta detectarla y meterse en Crashfree
Descomprime con 7z que es más fiable para flasheos
Pero si no me detecta ninguna de las dos pantallas?? Como lo hago??
