Tonius
- 26 May 2017
Bien bien yo aún esperando [emoji28]el mio ya me ha llegado del RMA, 1734SUS
Enviado desde mi LeEco Le Max 2 mediante Tapatalk
Semana 40. No está afectado.Buenas!
El inicio del post la verdad que no lo deja nada claro, o por lo menos yo no me entero...
Acaba de llegarme hoy un Ryzen 1700 UA 1740SUT ¿Este sería un afectado o es posterior a la semana 25?
Me descojono... yo compré hace 2 semanas el 1800x que envié a RMA porque pccomponentes no tenia procesadores 1700x de la semana posterior a la 25 para cambiarmelo y me ofrecerieron un reembolso, el caso es que lo pido a amazon y les indico además que pasarán nota al almacen para que me lo enviaran de la semana 25 o más... y almacen dando fe de que si lo era me llegó uno de la semana 19... en fin...
I have performed stability tests on the processor received with prime95 and this is the result:
[Wed Jan 24 18:39:09 2018]
FATAL ERROR: Rounding was 0.4942209719, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Self-test 336K passed!
[Wed Jan 24 18:44:29 2018]
Self-test 8K passed!
FATAL ERROR: Rounding was 0.4983900347, expected less than 0.4
[Wed Jan 24 20:34:33 2018]
[Wed Jan 24 20:40:21 2018]
[Wed Jan 24 20:47:24 2018]
Self-test 400K passed!
Self-test 12K passed!
[Wed Jan 24 20:52:28 2018]
[Wed Jan 24 20:59:05 2018]
Self-test 480K passed!
Self-test 18K passed!
[Wed Jan 24 21:04:08 2018]
[Wed Jan 24 21:09:43 2018]
Self-test 560K passed!
[Wed Jan 24 21:15:27 2018]
Self-test 24K passed!
[Wed Jan 24 21:21:42 2018]
Self-test 672K passed!
[Wed Jan 24 21:33:07 2018]
[Wed Jan 24 21:38:36 2018]
[Wed Jan 24 21:45:04 2018]
[Wed Jan 24 21:50:06 2018]
[Wed Jan 24 21:56:40 2018]
[Wed Jan 24 22:01:42 2018]
[Thu Jan 25 14:27:01 2018]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
FATAL ERROR: Rounding was 0.4577554542, expected less than 0.4
FATAL ERROR: Rounding was 0.493036002, expected less than 0.4
FATAL ERROR: Rounding was 0.4925764119, expected less than 0.4
FATAL ERROR: Rounding was 0.4988138619, expected less than 0.4
As you can see the last error in less than 6 minutes of execution ... the rest of the computer is stable because it had a 1700x installed so the memories are not.
How do we proceed?
me ha pasado lo mismo que a Sergioqx84 asi que he hecho otra solicitud a ver si va bienNo. El último email que me ha llegado ha sido como este:
Delivery has failed to these recipients or groups:
tech.atlcq1support@atlcrqasdc00.amd.com
The server has tried to deliver this message, without success, and has stopped trying. Please try sending this message again. If the problem continues, contact your helpdesk.
Diagnostic information for administrators:
Generating server: amd.com
#550 4.4.7 QUEUE.Expired; message expired ##rfc822;TECH.ATLCQ1SUPPORT@AMD.COM
Vaya , si veo que no responden o sale igual entonces utilizaré hotmail.. gracias por el datoAl final después de intentarlo varias veces con Gmail. Cree la misma cuenta pero con Hotmail y funcionó a la primera. Un saludo
A mí menos mal que respondieron la solicitud y ayer por la noche lo dejé en una oficina de DHL , osea que digamos empieza a contar a partir de hoy, según ellos mañana está allí , a ver lo que tarda , si va bien puede ser que el viernes que viene este aquíYa ha llegado el mio 1733SUS chino. 9 días ha tardado todo el proceso. Si puedo esta noche lo pongo y comento. Tengo la placa prime b350-plus con bios 1002 que ya lleva agesa 1006b. No se si actualizar a la última bios. Tengo unas corsair lpx 3200 hinyx a 2933 1.37v con esa versión de bios.
Una lástima maceh, ojalá te manden otro pronto.
¿Qué programas le pasais para comprobar el estado de la cpu? yo llevo usando el mio desde que llegó y no me ha hecho falta reinstalar windows, se reinicio solo la primera vez que lo puse y la placa me dijo, new cpu detected pero poco más...
